1 - 9 of 9 Posts
Allow me to play village idiot again. I purchased two new hydraulic cylinders from NPD for my 71 convertible top. When I pulled them out of the shipping box, lo and behold...no connectors for the lines! Just a bolt in the outlet. What do I do to remedy this problem? Is there some kind of kit I am unaware of, or do I have to "plumb" these things from scratch. (God help me!)
I'm no expert, but I would think that the hydraulic lines from the pump would have the fittings on them that screw into the cylinders.
Discussion Starter · #5 ·
On my old ones there are copper fittings and lines that the lines hook into which are obviously missing here. I am unsure on how to make them for the new ones.
Discussion Starter · #6 ·
No, they are the same hydralic ones that I currently have on the car. Just no leaks... ;-)
Discussion Starter · #7 ·
I do have the lines, but they do not connect directly to the cylinders on th old ones. They are "plumbed" with copper fittings and tubing.
if they have no holes for hydraulic fittings, then they obviously are not hydraulic and are the spring loaded ones for non-power top. they look identical except for the fittings.
Discussion Starter · #9 ·
They do have holes for fittings. I said in my original post that they had bolts in the holes. I just need to know how to add the copper fittings.
1 - 9 of 9 Posts
