I'm almost done with rewiring my 65 and have a question about converting to LED turn signal lights and sequential taillights. everything on my car is now working as it should, but when i put in the sequential LED taillights from Mustang Project they flash but not sequentially (they actually have a very quick flash followed by a longer flash). Additionally, the front turn signal lights were working appropriately when regular bulbs were in, but now with the LED bulbs, both sides flash no mater if i am trying to signal left or right?? I have installed the new flasher module that came with the taillight kit and can confirm that it has a good ground.
Anyone had similar issues with this?
thanks,
Greg
The problem I had was I didn't change the TS bulb in the 'Dash' caused me some funny problems - once I changed it everything worked OK.
I'm guessing you have the Falcon style dash, if so your turn signals problem is a result of both side sharing a single dash indicator light. you'll need one of these.
Isolator LED Indicator Bulb
From Vintage LEDS
