Recently, I had removed the manifold from my engine to replace a plug that was missing. When I pulled off the manifold, I lifted from the front first, causing a large amount of coolant to drain into the engine the block. Once the manifold was off, I sucked out all of the coolant and replaced all of the seals and put the manifold back on. I then drained my oil pan and changed the oil and filter. Now, when I start the car and check the oil, the oil is still registering with a white-esh tint. Could this be residual coolant? Or did one of the seals not seal properly? Is there any way to trace a coolant leak?
When I changed the oil, I jacked the rear of the car up so all fluids would go toward the drain plug. I poured oil through the engine until it ran out through the pan as the same color as the oil. Thanks in advance for any help.
Deathman68
Deathman68
