·Guest
Okay, I've been narrowing this problem down since I purchased the car. It is getting better, but it is still there.
When driving the car from 0-40 MPH the car stays very cool, gauge usually is below 1/4 of the gauge, just above cold. As I start to speed up the temp rises until it is about 3/4 of the way up (just below HOT). This seems to happen regardless of the outside temp.
So far this is what I've done:
1)Replaced thermostat with 180 (original was 196 that was stuck half open)
2) New 6 bladed fan
3) Fan Shroud
4) Water flush of cooling system (not just radiator)
5) Chemical flush of cooling system
Where should I look next? When I drain my radiator, it seems to drain very quickly so I do not suspect a clog there. I guess the water pump is next on my list. Does that make since. Is there anything else I should look at?
I have 2 weeks to solve the problem before it hits the highway for a 300 mile road trip to my wedding and I would like for it not to run hot on the way down there.
Thanks.
Slade
2) New 6 bladed fan
3) Fan Shroud
Thanks.
Slade
