The U shaped tube that connects at two points on the the intake manifold to the PCV valve. 2 fittings at the manifold and one at the PCV valve. What are the correct connectors to clamp the hoses to the fittings? Radial screw type (Wittek), tangential screw hose clamp (slot or no slot), compresson type "special" clamp, or spring wire clamp? All the same or different? Got three different ones on the existing setup and they sure don't look stock...
As long as I've gone this far on the restoration might as well get the right bits for this.....
Any info appreciated.
Thanks! AMK here I come....
