Greetings,
My recently acquired '65 had an inoperative speedometer (difficult driving without). I pulled the cable out of the T10 and found the gear was missing. Seemed simple, I checked the various websites for the correct tooth count and ordered a gear for a 4 spd (C2DZ-17271-J). Installed the new gear and went for a ride. No speed indication, but I notice the odometer is running backwards! OK, does a T10 use the "reverse" 3 spd / C4 gear? If so, I assume the 4 spd gear is for a toploader?
I would appreciate someones expertise.
I used the 3a rotation gear for my t-10. I was told all 4-speeds take the same rotation for 65-66.
Paul
Paul:
Do you mean the "A" gear (16 teeth) for a 3 spd transmission?
Thanks,
Check with NPD. They have type 3a left hand rotation and type 3 right hand rotation. 4speeds should be using 3a. There is a picture in their catalog of the 2 types. I even have an extra speedogear laying around from my old T-10 that I bought if you want it but it has 18 teeth I believe. PM me if you would like it.
Thanks for the info and offer. I have an NPD catalog on order and I will check the pictures out and compare it to what I have.
