I have a prospective customer that has asked me about changing his drum-brake, 4-lug front end over to disc brakes and 5-lugs. For those of you who have done this conversion, how much did it cost in parts (new or salvage) and about how many hours did it take to do? Thanks.
Using a granada set up, used from the salvage yard ($150) with new rotors, calipers, hoses, etc. from Auto Zone ($225) and 8 hours of work (your $$), that is the "cheap" route. However, the rest of the steering needs to be changed out to match the new spindles, so that is another $300 for parts, including pitman arm, but then you have 5 lug hubs in the front, so that means new wheels, and then you would have 5 in front and 4 in back. So then, you are into changing out the rear end, drive shaft mods, . . . .
I think this is a little bit of a tough call. How much money is the customer willing to spend? You could do the SSBC, Granada, 67-73 Mustang or a kit such as Sacarebird and use GM calipers or what ever bargains come along.
If the customer wants the five lugs all a round and the disc then it is very pricey becasue you are replacing the entire front end and the rear.
If they just want front disc brakes, Scarebird makes a conversion for the stock four lug spindle.
John Harvey
