1 - 10 of 10 Posts
Working on the wiring for my Contour fans, I know they are rated at about 30 amps, and have seen tests where they show around 103 amps on initial start up. What size fuse should I use for these fans. I plan on using separate fuses, one for each fan. I'm also using an AutoCoolGuy controller. TIA, John
Just some guy
No doubt the exact size could be looked up somewhere but I would use a 40 amp. Such fuses generally can cope with the momentary high draw of startup so you fuse for actual run pull. Plus a little.
Thanks! I can get 40A slow blow mega fuses on Amazon.
[/QU
SHOP MAUNUAL shows a 60A fuse and 2 relays .
747557
Hi, how ya doin
Would a re-settable breaker be a better option? Just in case you're stranded without a fuse?
I thought about using a breaker, but most CB's are sensitive to heat and their rating can degrade if subjected to excess heat.
I'm running a 30 amp fuse for each fan going to a single ground based controller. Been running that way for 2 years with no issues.
-Shannon
If you're running an autocoolguy controller, I dont think you'll have to worry so much about the spikes st startups. Unless I'm wrong, dosen't the ACG controllers have soft start to avoid that? I run a flex a lite PWM controller and havent had any issues with mine running both fans other than my ground going bad one day and trying my controller.
I missed the part about the autocoolguy controller. That's what I have. Bdub4u, your're right, that controller has a soft start that's why I'm running only 30 amp fuses.
-Shannon
1 - 10 of 10 Posts
