I have a 68 GT Convertible. The courtesy door lights, and the 2 under dash lights that would light up the floor mat area, and cigarette lighter do not work. In addition, the instrument bezel lighting is very dim which may be a separate issue. So far i have done a conductivity test on both door switches and they are fine. I have replaced the headlight switch which apparently the lighting described above, passes through. All fuses are fine in which most have been replaced or continuity check was conducted for integrity. A few years ago the driver door courtesy light wiring that runs between the door and door jam severed due to 50 years of opening and closing door. I reconnected the wires with butt connectors and it worked temporarily. The car was recently painted in which the doors were removed painted and reinstalled with new harness for driver side. I thought this would resolve the issue to no avail. A friend indicated this lighting and lighter issue could be as a result of a grounding problem. Any thoughts, suggestions or input would be greatly appreciated. Thanks, Kevin
