1 - 20 of 27 Posts
AJE Colt 65 k-member & a-arms, notched towers, foxbody strange coilover struts, sn95 cc plates, aje drop spindles, 03 cobra brakes.
I'm assuming that CJ intake isn't going to fit under a stock hood unless you have a scoop/cowl?
Also what chassis brace is that running under the TB?
Discussion Starter #9
It's going to be real close, if it doesnt fit thinking i may cut a small hole for clearance and so some sort of factory looking scoop. It's adjustable monte carlo bar that fit perfect without mods.
Another one for you...what oddball combo of camber/caster plates are you using? That's a whole lot of adjustment bolts.
sn95 maximum motorsports cc plates.
So what are you using for suspension? I doubt you have upper control arms with that setup(which explains how the Coyote fits) SN95 struts on an aftermarket LCA?
P.S. Looks like your dipstick is touching the shock tower in one picture...what kind of clearance are you looking at around the engine?
Discussion Starter #16
AJE k-member/a-arms, foxbody coilovers, sn95 cc plates, aje drop spindles, 03 cobra brakes. Shock towers are trimmed flush to outer frame rail on bottom, the dipstick is close, but not touching. Motor went in with trans and headers attached, so enough room to clear.
1 - 20 of 27 Posts
