1 - 20 of 71 Posts
Just wanted to see how many folks have either completed or want to swap in a coyote. I figure some of the thoughts and headaches would be similar no matter what it was being transplanted to...vintage, fox body, cougar ;), or whatever you fancy.
Things like accessory brackets, power steering, stand alone ecu, etc. will be universal dilemmas.
If you have wanted it or have already done it, chime in and we can keep this thread going for those to come as the price comes down and the swap becomes more common.
I've started my research and will post up some of my finds as I make my list and check it twice...I know I have been naughty, but the coyote swap is so nice...
I am in the process of installing a Coyote crate engine in my daughters 70 Mustang convertible. The engine is large so the shock towers are gone. Rod and Custom rack and pinion. 4r70w automatic. The car has been completely redone as a restomod. The actual work to do the swap is not that hard. Unfortunately life keeps getting in the way and I have to stop for a while and than start back at it.
Coyote/6 speed planned. Currently on hold for the holidays, a new toy, and some truck maintenance. Griggs front suspension in, rear suspension fabbed and ready. Have to make new cover plates for shock towers which are mostly gone. Plan to add front brakes, finish steering system, fuel tank/lines, and measure for wheels/tires after that.
Engine/trans a little later in '19. Once I've the engine/trans, then issues with PS, brakes, AC, and all the other time/money consuming issues can be addressed. Depending on hood clearance, I may install blower on the motor. Just some of the fun of this project.
70sum...can i come live at your house? lol
Very nice convertible...add in the restomod and it will be one very cool car indeed. Love the color and the coyote.
In process now....step #1 research the hell out of front suspension depending on your budget. The front suspension is key to how things will fit, I'm doing AJE (still have shock towers).
No question that Coyote engine is one awesome motor. I have a 2017 Mustang GT and love driving it. But to do all it takes to swap that motor into my 68 just doesn't seem worth it. Not only do you have to purchase a Coyote and supporting hardware, but you have to remove the shock towers and change the front suspension. Sure you would have a pretty awesome classic Mustang with rack and pinion steering. To those of you that have done this swap, was it worth it? What would this project cost in parts?
Discussion Starter #8
A lot of considerations have to be evaluated before you can determine if its worth the swap.
What are your plans for the car? Sunday driver, everyday, trailer queen, ect..
I'm planning for everyday so efi was a definite for me. I want a minimum of 400 hp.
What's in the car that you are starting with? Project car with no motor, driving 302, ect.
My last build was a 331 stroker and I was close to 5 grand with no manifold or efi on it yet. Coyote can be found around that price all the time.
Yes, lots of work on the front suspension but if you are into restomods you are probably going to be spending a bit of coin anyways.
After I got my parts together last time I realized I could have went coyote and had a cool setup and a very reliable car for nearly the same money and work.
Sent from my SM-G960U using Tapatalk
1965 fastback coyote planned. Thinking about doing it with a 2018 forward Coyote and finding away to get the Automatic 10 Speed to come with it. I continue to waffle on whos suspension i will use between TCI, RS, Heights and so on. I also want to add a power adder and want it to be turbo but the complexity and limited space might force me down the Super Charger path.
Mine is still in work (more like banner because of life). Using a Gen II crate coyote. Link to my build thread is in my signature. My main objective was to use as many factory parts that I considered consumables, i.e. brakes, clutch, etc., so that if I had problems down the road I could easily find parts from the dealer or parts store. For example, I wanted great brakes (highly subjective) so I used the hydroboost unit from an 03 mustang cobra, '14 GT500 mustang brembo front brakes, and 2008 Challenger SRT8 rear brakes. I even went as far to make my main front suspension crossmember removable so I could service oil pan leaks in the future and not have to remove the engine.
Discussion Starter #14
Nice to see all the swaps. I searched and didn't see a lot of coyote threads...be nice to have some information in one spot.
I am planning to do a Coyote swap on my 65 coupe as part of a pretty in-depth restomod/restore/rebuild. I already did a Coyote swap on my 1996 Mustang Cobra American Iron car. My 65 isn't unique or special other than the fact that it was my first car and I've had it since 1990.
It was originally a 289-2 bbl car, C4, Pony interior. I'm going to do a street/track build. It currently has a 255 ci - 2bbl engine, T5 trans, stock 8" rear, 2001 Bullitt rims, 245/45-17 tires, and lots of rust. It will likely be a complete disassembly and rebuild. I do a lot of road racing so it'll have a partial cage, at least.
Thanks Andrew!
That's mine. 65 Coupe, Coyote with twin GT35s, TR6060, Wilwood brakes, fully upgraded suspension and waaaaayyyy too much custom electronics work. Running an AEM Infinity, I plan to have traction control, etc in place as well. I'm using stock alternator and AC positioning. Rack and pinion with electric power steering. Brakes/clutch are on a Wilwood reverse swing manual dual master under the dash (7" swing). I've driven it, but only about 200 yards so far. Plan to have it out tuning/debugging this spring, just finishing some wiring/interior work right now.
My favorite picture:
Engine wiring:
Engine bay:
And front suspension mostly done:
Paint work is mostly done also:
I like your oil accumulators you added to the bottom of each turbo. Most builds I've seen with low mount/rear mount turbos had oil issues until they added some sort of accumulator before the return pump. Very neat and almost missed it for a second.
Yeah, cold start and high RPM conditions worried me for smoking, so I built those. So far, so good, at least on cold start/warm start there is zero smoke out of the car.
1 - 20 of 71 Posts
