I put the CPP Mini subframe on my 66 convert. Today I was test fitting the spindles and on the lower ball joint there is a spacer. It doesn't say in the instructions where the thing goes. SO where does it go? Here's a couple of pics of where I have it now.
This^^^^ the spindle has a taper and so does the ball joint that must mate. It's probably a MOPAR ball joint, the taper is the same but up by the threads it's longer. Spacer under nut and washer.
1967-1970 Ford Mustang Viking 350lb Front Coil-Over Shock Conversion Kit With Rear Adjustable Shocks. Front coilover shock kit with 350lb springs. Viking Double Adjustable Front Coilover Kit with Rear Shocks Features.
I have the same set. If you used it without a spacer, spindles would sit too low on a balljoint causing interference between spindles and lower arms. In addition, you'd need tall castle nut since it would be lower on a thread
So my best pass was 13.9. As far as specs, the 289 is .030 over, stock compression (9.3 I think?), Comp cam .512/.512 lift 280/280 duration, Trick Flow Twisted Wedge 170 heads, Performer RPM Air-Gap intake, 570 Holley Street Avenger, and Hooker Comp long tubes. As far as getting the power to...
Been searching online and this forum about the reviews on a 1966 Shelby style fiberglass Hood . Most of the reviews I found are 10 + years old . like to get some current feed back
I have a steel Hood with a fiberglass scoop and need some work , body shop suggested a fiberglass Shelby style hood...
I am installing Sniper EFI in my 1969 and are looking for a throttle cable bracket that works well with a stock throttle cable. I have a Mr. Gasket bracket I installed that works but I don't like the way it bends the cable out to connect the throttle body linkage. What bracket works with the...
Looking into piecing together a basic underdash A/C system for my 68 coupe using a Mark IV type evaporator. Vintage Air has a nice reproduction unit that Summit has for $300. There are also many cheaper underdash evaporators on the market.
https://www.summitracing.com/parts/vta-672001vhy
I...
