66 Mustang
In the past I recall reading issues about the tapered ball joints having fitment issues. Not sure what you are looking or wanting to do with your Mustang suspension wise. But I'll give you two suggestions for board members that have a vast knowledge of suspensions, John and Sherri at Opentracker racing products and Shaun at Street or Track. They are great to talk to and won't over sale you something just to make a buck. Another knowledgeable member is GT289, also Huskinhano
66 Mustang
No, I've spoken to Opentracker and Street or Track and that's the route I'm going.
I just seen it, and was curious if anyone has used it at all.
A friend of mine used the kit they make for his '66 Chevy II, which has a very similar front suspension to the first gen Mustang. Only issue he had was they sent the wrong springs for the coilovers, which they replaced promptly. He only has about a 100 miles on it so far, but is very happy with the much improved handling and ride.
About the only issue I see with this setup is the entire weight of the car is suspended off the two sheetmetal shock mounts, which are not inteded for that type of service.
Reactions: cturboaddict
66 Mustang
Yeah, I rode in the same car with the same setup. Wasnt bad at all.
"{........About the only issue I see with this setup is the entire weight of the car is suspended off the two sheet metal shock mounts, which are not intended for that type of service.
^^^^^^^^^ this ! ! !
plus, you can get similar or BETTER handling and spend less $$$ and MUCH less time by going to Opentracker's web site, calling John @ Opentracker, etc.
Z
I was looking at this kit as I really liked the one piece lower control arms. And I also like the coilovers, syou can adjust the height without having to remove and trim the coil springs and you can add height back. That I already had a set of Global West uppers is the only reason I did not go with this kit.
