1 - 2 of 2 Posts
Just remembered my '65 garage shelf had this problem after looking at it again. Right at the outer edge of the corner between the upper and lower door hinge is a big Ol' humongus crack about 8" long and about 1/8" at the widest. I guess I'll have to remove the door, beat the separated part back together and weld it together.
Question: Should I weld in reinforcement behind it or will a solid butt weld do the job?
Maybe I should take this to a pro since I never even taken welding classes and just have a small Lincoln Weld Pak 100 with flux core wire.
Suggestions?
Thanks!
Dean T
1 - 2 of 2 Posts
