I saw this render on Instagram (I’ll attach down below) and they had the exhaust exiting from the quarter panel right above the torque box. It was a big 4-5” pipe. It seems the only way to do it would be to run the exhaust up through the floor pan before the torque box and then run it out the side. But then you have exhaust pipe inside the cab. So do you guys see any other ways to accomplish this? I was thinking maybe a good quality exhaust wrap and then build a box lined with heat shield around the part that is inside. As a secondary question can you run a single pipe for a V8 and be ok? I’m talking like a 4”-5” pipe. Interested to hearing your ideas and thoughts.
