i was doing a little work on my exploder today and i noticed the pass rear wheel only had 4 lugs on it so i looked and the stud was snaped off and the other 4 are bent. what can i do. i tried to pull the drum off but it will not budge losened the adjuster and the drums shoes and hard ware is less than 3 months old why cant i get the drum off. and how much would it cost for a shop to replace all 5 studs on the pass side rear
Beach Bum
Shouldnt cost to much to replace the studs, they just come out the back of the axle flange. It is probably about 1/2 hour job. The drum might be stuck because the studs are bent. :(
once you get the drum off, a good rap with a hammer will knock out the old ones and you just drive the new on in place. or put a nut on and wind them into pl;ace. take a hammer and rap one side of the drum on the face of it right above the studs and see it that will loosen it.
