I replaced my headlight switch in hopes it would fix my dash lights but no. Replaced the fuse, no. Is there regulator or something else it could be? I remember something on the back but just want to make sure.
easy things first. check the fuse(you might have blown it when you replaced the switch. the check the contacts and maybe fiddle with the bulb holder(i fixed my turnsignals like that) make sure that the bulb is good and then start to check the wiring.
I have no dashlights ( can't see my guages if I drive at night). Like I said I checked the fuse, replaced it. All of the bulbs are not working. Possible that they all blew at the same time? The headlight switch works when all the way turned it turns on the lights under the dash, floor lights. I have to check the wiring this weekend.
if you shorted the circit out then yah they can all blow from too much voltage. check out the voltage regualtor and find out where you are loosing the connection. before or after the switch.
