1 - 2 of 2 Posts
Guys, thought you may want to see some of the fun. Some of you guys do this regularly, others may want to see the pain, I mean fun
I got all the way to a fully prepped and cleaned block with all clearances checked and the crank installed. Tomorrow, I will start sticking pistons in holes :)
I used Diamond pistons sized at 4.272. We planned on a .005 clearance, so that is a bore size of 4.277. However, my new machinist is able to hold a tolerance to the 10 thousandth in bore size!!!!!, so we custom fit each piston to each bore for a true .0050 fit.
Actual piston sizes ranged from 4.2720 to 4.2726, really insignificant, but he offered to get that fussy, so we did :) I got the block back Friday and started my assembly today
My job today was to file fit all the rings, chase all the bolt holes, then wash everything pretty, double check bearing clearances and get the crank in. I got there and said enough for today :)
Here are a few pics. First is a picture of my little cheap, but very effective piston ring grinder. You first fit your ring to the bore, measure, then keep cutting until you get there. It cuts VERY fast, you just square the ring on the table, then when all done, clean the edge a bit with a small fine file
http://members.cox.net/my427stang/Mustang/Ring%20gap%203.JPG
The way you measure, is you first put the ring in the bore, then use a piston to make sure its square in the bore. Here is a pic of that (the ring is in the cylinder, then I push down with the piston
http://members.cox.net/my427stang/Mustang/Ring%20gap%201.JPG
Pull the piston out, and measure the gap with a feeler gauge, if its tight, go back to the grinder, if its right, clean up the edges with a hand file, if its loose (slow the F%$^ down next time LOL)
http://members.cox.net/my427stang/Mustang/Ring%20gap%202.JPG
There are a lot of changes to how pistons and rings work nowadays. Common practice is .004-.005 of ring gap per inch of bore for the top ring and 30% more for the second. Reason for this is two fold, one you dont want ring gaps to close to zero when hot, BUT the reason for the second ring gap to be wider is to prevent trapped pressure beneath the top ring AND allow some clearing pressure past the 2nd ring to pressurize the holes behind the oil ring pack.
I promise it doesnt cause blowby, it actually makes top ring sealing better due to the fact the pressure beneath it doesnt cause it to float in the land
I have a 4.277 bore x .0045 = .0192 ring gap, however, I like a little more ring gap, so I rounded up to .020. For the second ring, I took my .0192 number, and multiplied it by 1.3 and came up with .025, thats what I used.
When done, a real nice bath LOL the engine was already hot tanked, but I have a pile of brushes for any orfice LOL SO I washed first with cheap WD40. I like to use WD-40 first because it'll break up any oil-based gooch that may be around. You can see in the next two pics I did some scrubbing. I then went to hot water and soap, then back to WD_40 so it wouldnt rust. You'd be amazed at how much still comes off on a rag after the last cleaning
http://members.cox.net/my427stang/Mustang/Clean%201.JPG
http://members.cox.net/my427stang/Mustang/Clean%202.JPG
I did get the crank in and ready for pistons, checked thrust bearing clearance as well as a quick Plastigauge check for the already checked bearings, but unfortunately it got a little messy in the garage, I got a little tired and grumpy, and I didnt take pics of that. However, if you guys care to see, I'll take some more tomorrow with the rest of the short block assembly.
4 day weekend planned for nothing but 489 FE building LOL
Keep 'em coming!
- Gord
1 - 2 of 2 Posts
