Hi gang!
I can't remember which one of you told me about the new DESNO Irridian plugs but I wanted to thank whoever it was.
THEY WORK!
If you need a tuneup or want MORE POWER, try them!
That is, if you're willing to spend $13.00 for each spark plug!
See my article on them here if you like
http://jmichael.info/DENSOplugs.htm
THANKS
Doc the moneymanager
http://jmichael.info/queenmarytrophy.jpg
.. im a skeptic... and i looked at the site, those cars on the dyno only gained about 5HP with using those plugs.. is that something you can really feel in the seat of the pants? thats pretty crazy if it is, but..with my budget i dont see how 100 bucks for plugs is such a great idea... but if it cured your problem then all the power to you. im just scared to throw 100 bucks at some spark plugs that can be had for 1-3 bucks a pop and perform decently in my car. *G*
That's interesting, the only time I ever noted a difference in a spark plug was years ago when I put Nippondenso plugs into my 240Z. I could actually feel the difference and the MPG's were slightly better. I think it is the same company, but not sure.
Densos are one of the hot ticket spoark plugs for making late model supercharged fords run smoother HOWEVER, they are very prone to insulator damage. Just a little detonation and theyre junk .Having experience with many plugs Ive found the NGK TR plugs to be more durable, a LOT cheaper and the end result is the same.
