Ford Mustang fastback GT390
Looking at buying 1 of these, any thoughts on performance good or bad.
Junk.
.... if you don't want to spend $150 on the K-code fan, a clutch fan will free up HP and reduce engine noise.
The clutch you need is the Hayden 2710. You can use 2711 is a 3/8" shorter clutch fits better. The fan blade is Derale 18" 17118 or 17" 17117 - measure to see which one fits best. You'll also need a stud kit, as using bolts in this application is a serious lesson in frustration.
I had the kind of feeling that it was crap, so went for the derale 18” steel fixed fan instead. 👍
