·I need to replace my starter motor, and I was able to remove the bolts fairly easily. However, there isn't enough room to wriggle/twist/remove it. The AT fluid lines and steering linkages are pretty much in the way. So, I have to remove one of them first, right? (Duh!) Which would be better?
I would guess the AT lines, if I can easily drain and replace the fluid... Alternatively, I have to remove the ball joints, then have the alignment checked later...?
Any words of wisdom would be helpful. Thanks in advance.
