1 - 14 of 14 Posts
Getting ready to upgrade the 68 to orig8nal style Ford disc brakes. Sorted out a caliper issue on another thread. Now have a few questions I need to answer before ordering the final parts.
I am swapping the front spindles with a set of D0ZA (70 Mustang) spindles. As I understand it, they have larger bearing posts and took a slightly larger tie rod pin.
I already have a set of 68 Rotors.
So on to the questions:
1. Will all the 68 parts (rotor, splash shields, hoses etc.) not including the tie rod, fit if I swap out the bearing races and bearings for 70 bearings?
2. Is there any difference between 70 rotors and 68 rotors? Should I return the 68s for 70s or just replace the races?
3. Is there any advantage to swapping to a 70 tie rod vs. using the little adapters that make the 68 tie rod fit?
4. Is there anything else I need to consider for this swap?
5. What are people using for brake pads? I changed my 94GT to “Red Stuff” pads. Very happy with them so far. Any experience with them on a classic?
Use the right tie rod, they’re cheap enough. As for the rotors, if they’re in good shape I’d just change out the races and bearings.
Very simple.
Get A12-A13 bearing sets.
Remove races out of 68 rotors--Then install A12-A13 races.
Tie Rods--JUST PUT ON 70 outers! No cotton pickin bushing, spaces at all.
Very simple.
Thanks , Greg, Dan, that’s what I figured was the best answer. The bearings will be here this afternoon. What’s the easiest way to swap the bearing races.
Discussion Starter #10
Nope, the HF race installer didnt work for me.
I rented a set from AZ and it wasnt the right size. They opened a brand new box with the same p/n and it was the right size.
Discussion Starter #12
Good to know, thanks
A piece of brass rod and a hammer works well to install races in the hubs. DO NOT use a steel drift or punch to drive them in as the race is hardened and hammering on it with steel could possibly fracture it.
Discussion Starter #14
Interesting. I’ll be sure to be careful. I got a race install ki5 from Autozone. Hoping that will work well. I still have to get the old ones out first.
1 - 14 of 14 Posts
