Kelly,
Does the exposed portion of the rubber look original?
Uhmmm, did you happen to notice the date on the post you replied to? I do this too sometimes...If your car is a 66, it should have weld studs for the clips, not screws. My 65 had screws and the new screws come dipped in a heavy wax like Cosmolene which protects them from leaking. Why do I have absolutely no problem with Carpenter gaskets. Fit perfect with no leaks using a CarLite windshield and original rear glass. Orginal trim snaps right in with minimal effort. Steele sells the Carpenter gaskets even though they produce most of the products they sell.
Somehow I got referred to it from a current thread and did not notice the original date. However, it was applicable to the current discussion.Uhmmm, did you happen to notice the date on the post you replied to? I do this too sometimes...![]()
Not everyone has the same experience with the same products. I too installed the Carpenter, and they stuck out from the body enough that I didn't want to test fit the moldings figuring I may not be able to get them back off without damaging them.If your car is a 66, it should have weld studs for the clips, not screws. My 65 had screws and the new screws come dipped in a heavy wax like Cosmolene which protects them from leaking. Why do I have absolutely no problem with Carpenter gaskets. Fit perfect with no leaks using a CarLite windshield and original rear glass. Orginal trim snaps right in with minimal effort. Steele sells the Carpenter gaskets even though they produce most of the products they sell.
You've tried them all?Daniel Carpenter makes the best windshield gaskets period. They are also made in America as well.
