Good evening y'all! FNG here from Mississippi, with a question for you experts...
What's the distance between the frame rails (inside measurement)? I have measured mine right in front of the firewall, at the shock towers, and at the front, and the front is about 1/2" wider. The rear and mid points measured the same. I just wanted to make sure that a)the frame rails are supposed to be flared out at the front, or b) my frame rails are flared out and the front and they shouldn't be.
Thanks for your help!
Welcome to VMF!
Haven't had to take mine down to the rails, so can't answer from experience. Will try to measure mine today and let you know. I am sure other guys have an answer.
I'll also be under mine today working on the suspension and brake upgrade, so I'll put a tape on mine as well (provided I can find my tape ;) )
