Banned
I need a autolite/motorcraft distributor center shaft. Rust free, but dirty is fine. I'll take a dizzy without points, condensor, cap, vacuum advance.... all I need is the center shaft in good shape! If you have an orphaned part or dizzy that's not worth the time for a rebuild, I can use it. Looking for it on the cheap, with gratitude.
Hi Steve,
I'll check my "stock" on Friday, but chances are I have what you are looking for. I'll give ya a call Friday afternoon and let ya know for sure.
Banned
Thanks Dean! I'll give you the whole, sad story later on.
what is the aplication, the center shafts are different from the 289 to the 351. the 289 has a 1/4 inch female allen hole for the oil pump shaft & the 351 has a 5/16
Banned
Quite right, and I should have been explicit, rather than expect people to go through the bother of looking at my profile. It was for a 289.
It looks like Dean has taken care of my current problem, though... thanks for (what I assume) was going to be an offer to help out!
