Well, in preparation for lighting off my car sometime this week, I want to measure/adjust the advance curve on my car. I've got a Mallory Unilite distributor (no vacuum advance, 3 wire hookup). I understand that it is recommended to have 30 degrees of total advance. How do I measure this? I have a craftsman inductive timing light (without a dial on the back).
Thanks in advance for the info.
http://albums.photopoint.com/j/View?u=1571478&a=11942550&p=43703435.jpg
I run 16 initial with 36 total. Without a dial back light it might be hard, the damper may not have marks after 35 degrees. I kind of fudge it because i'm so close to 35 anyway. What total timing are trying to run?
I had 30 degrees of advance at first, i then adjusted my dizzy to anly give me 20 degrees. Didn't want 46
degrees total.
1966 Mustang Coupe, 302 custom roller cam, holley 650dp,http://www.289mustang.com
http://www.289mustang.com/images/vmfcar.jpg
I believe Mallory sets up the Unilite with 24 deg of mech advance at the factory. You might want to start at 12-14 initial and see what happens. The Mallory web site has all the specs if you need to check.
65 FB "J" 302 lots of mods. 94 GT K&N only.
http://albums.photopoint.com/j/view?u=1590489&a=12113030&p=43871256.jpg
Discussion Starter · #5 ·
AWESOME ARTICLE! Thanks for all of the info!
