·Guest
I just ordered a rebuilt distributor for my 66 coupe 289. It is the correct single point vacuum advance type.
Two questions.
1. Where does the vacuum hose from the advance, connect to? I assume it’s on the carb. I have a Holley 4bbl. It has two capped off nipples for vacuum lines. If you’re looking at it from the front, one is on the front-most, top left corner, sticking straight out to the left. The other is about 2 inches behind that, coming out toward you at an angle. Is one of these the spot?
2. How hard is it to swap distributors? Does it just pull out? I know I’ll have to reset the timing, but is there anything else major involved?
TIA
DAVE
MCA# 48565
Two questions.
TIA
DAVE
MCA# 48565
