For those that are cheap like me and like to make your own things that are simple to make (more time in the shop is a bonus!), I thought I'd post up dimensions to make your own camber eccentric plates similar to what Pro Motorsports and TCP carries. There are multiple variations of these out there, ranging from multiple individual plates with single hole, to single plates with two holes, to this version with a single plate with three holes. I don't see any strength concerns with having more holes, and if I had multiple plates I had to store they would likely get lost over time. So anyways, below is a picture of what the plates look like finished (from TCP website), and attached is a PDF with dimensions to make your own. Two plates per control arm are needed, and the hole in the lower left corner of the plate is to help you keep orientation of the plates on each side of the control arm. You want the hole to be in the same corner so that the bolt is straight.
The dimensions were taken from an older iteration of the Pro Motorsports plates.The current ones use two holes instead of three like mine. Since this is from an old version and it appears other companies have stolen the same idea, I don't see it being an issue in posting these drawings. You will likely want to up the thickness of the plates to 0.25" since it is more common, and I highly recommend adding the number markings so that you can keep track of the increments. Either use a number punch, scribe the number, or even a permanent marker. As you can see in the TCP version below, they don't include these marks nor do they have the reference hole. I would think the TCP version would be a pain to keep track of.
Hope this helps other DIY guys.
