Forgive me if this is a redundant question, because I thought I had posted it already, but cannot find it in any of my previous posts. Here goes: Due to financial limitations, I have elected to put the motor back together without putting a hotter cam and the required hardware (i.e. springs, rockers, push rods). I will leave it all stock (in very good shape w/ low miles on rebuild) except for the new Edelbrock intake, carb and headers w/ Flowmaster American Thunder exhaust system. Should I install the 1" carb spacer, or will it not matter on this iteration of this motor? (FYI: I'm holding off on the cam until I can pop for some better heads)
Shannon a.k.a. The ShanMan! /forums/images/icons/cool.gif
66' Vintage Burgundy C-code coupe (mine)
95' XLT Ranger (mine)
01' GLX 1.8T New Beetle (hers)
For the price of a couple of carb base gaskets give it a go.
Rarely have I been unhappy with using the spacers
Greg B
Definitely do install the carb spacer (phenolic will insulate carb from heat better than aluminum).....it's also a good place to port the PCV system...
The only remaining concern will be hood clearance to the air cleaner...
Pat
Install the spacer. However, CAMAchinist, since I've got the 3" reverse fiberglass hood from Mustangs Plus, with edelbrock stuff (cam, valve springs, intake and carb), should I go for a larger spacer? I think I can install a 2" or more, as the hood clearance is not an issue.
Gone but never forgotten
Just don't go expecting any miracles from the spacer. I installed one on my Performer intake (prior to the Performer RPM swap), and noticed no difference. There probably was a difference, but it would need the accuracy of a clock to be able to tell /forums/images/icons/smile.gif
Discussion Starter · #6 ·
I guess that I should put it on now, so I dont have to do it later, after I have moved on to other areas that need attention.
BTW: what EXACTLY did you come up with for throttle linkage for your Edelbrock carb?
