My 69 302 Mustang has a steel scatter shield bell housing and the instructions stated that it needs to be aligned to the engine block for best results. This was done and I used special offset dowel pins to give the correct alignment.
On a friends 302 engine, we are fitting a used aluminium bell housing for a TKO600 gearbox. Do aluminium bell housings need to be aligned as well or are they regarded as being more accurately machined compared to a steel one?
Thanks.
Jeremy.
68 Mustang Coupe
A factory ford bell housing or an aftermarket one? Factory ford one I would say not necessary, and aftermarket one I'd say it wouldn't hurt to check it.
Factory bellhousings are machined to factory tolerances. Aftermarket can be hit or miss depending upon the company. Regardless, it doesn't hurt to indicate the bore, just because.
Are you using a dial indicator with a magnetic base attached to the flywheel to "dial it in"? I would do it just to reassure yourself that it is within tolerance. If you don't do it and the car has a vibration you'll always wonder if that's the cause.
