i want a aluminuim one just not the high price i am not going to invite guys under the car to look at it.
chris
summit's are 89.00 dollars
Vendor: Trick Flow Specialties
Product Line: Trick Flow Aluminum Transmission Pans
Material: Cast Aluminum
Finish: Cast
Extend the life of your transmission.
Ford: C-4 transmission, 1 qt. over OEM, cast aluminum, transmission pan
This Trick Flow transmission pan is made from cast aluminum. It holds an extra quart of fluid and is finned to help the transmission dissipate heat for maximum efficiency. The pan comes complete with mounting bolts, a drain plug, and a new gasket.
Sold as a kit.
I got a new chrome trans pan with a drain plug for $24 with shipping from Motorchrome.com. Has about an inch of extra depth over the stock ones.
There is a guy that makes and sells them in this area from Charles City, Iowa. They are about 60 bucks and very nice. A friend of mine has one. I will try to locate a phone number for you, Just send me a PM if you are interested.
Kevin
