Does these parts needs lubrication
515 Views 10 Replies 8 Participants Last post by  tb65m66
Hi,
I am wondering whether these parts need frequent lubrication, I have just rebuild my hinges and I had to play with the small turnbuckle on my 67 Mustang Ringbrother hood hinge, but I just realized that these parts are dry do you think these parts need a little bit lubrication ? if so what type can you please help me on this subject.
See less See more
2
1 - 11 of 11 Posts
I'v never oiled any of them parts in all my decades. But , I do oil the door hinge pins and door latch.
Reactions: 1
yes, you can oil them...
Reactions: 1
For places where you don't want dirt and moisture to collect, like it does to petroleum-based products....
See less See more
Reactions: 3
Thanks yes that was my concern, a normal grease could collect all the dirt, so thanks for the recomandation.
I use engine oil but I like to keep a very clean latch with a regular wipe down.
Seems to me my copy of the original Ford maintenance manual mentioned lubing the hood latch assembly. I'd have to find it and check though. In any case I had to lube mine on my '67 as I couldn't even work it until I did. After restoring it I had to lube it again for decent functionality. I think I went old school with lithium spray grease.
From the 66 Ford Shop Manual:
Font Rectangle Material property Parallel Number
From the Global Spec website :
I think I'd keep it simple and go with @GypsyR
See less See more
2
Reactions: 4
I have used plain old WD-40 on the hinge points for the latch mechanism. Worked very well.
Thank you very much.
You're welcome. This is what VMF is about.
1 - 11 of 11 Posts
