I welded in my passengers side cowl tonight, and was working on doing the firewall patch, when it looks to me that the patch upper lip fit is off. I don't want to weld something that is incorrect in the car.
Here is the side cowl.
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_41_full.jpg Larger Pic
Here is the drivers firewall fit.
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_42_full.jpg Larger Pic
And again:
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_43_full.jpg Larger Pic
Here is the passengers side which looks to me at least like the lip is to high. Now I know I can cut this and rebend the lip with my hammer and dolly if that is correct, but I don't know how this should look since the whole corner was missing from both sides. Which is correct?
Here is the fit overall showing that the bends all line up:
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_44_full.jpg Larger Pic
Here is the Problem as I see it:
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_45_full.jpg Larger Pic
And Again:
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_46_full.jpg Larger Pic
And one Last Time:
http://memimage.cardomain.net/member_images/1/web/2641000-2641999/2641349_47_full.jpg Larger Pic
I have had to massage most of tha panels to a point. The part I don't know about is how the firewall is supposed to meet with the side cowl at the lip. Is the corner supposed to be fairly level on the upper lip? I can definately make that the case, I just need to know if that is correct.
Jon,
This will hopefully give you an idea of what it should look like.
http://mysite.verizon.net/vze22kvh/Frankies_65/rightsidecowlnewpanel4fullsize.jpg
You can find more pictures on my cowl repair pages if it will help.
Discussion Starter · #5 ·
Thanks, that shows me what I was thinking originally.
Here's another shot, from mine:
