My Dome Light Issue
1968 Mustang Coupe 289 V8 C4 is bone stock all original, made 8/25/67
The dome light does not work with both doors open and the headlight switch turned all the way CCW (to turn on the dome light). Here is what I have checked.
1. The light bulb is good. 2. The dome light fixture has a good ground from car body to fixture and or the bulb side. 3. After burnishing the center of the socket, there is no 12v to the socket (car battery was connected). 4. Having reviewed the 1968 Mustang shop manual page 19-48 (interior light schematics), it indicates there is a fuse in the electrical circuit (circuit 37A power to circuit 54) Am I correct about this and where is this fuse? 5. Just to be sure, I checked all the fuses in the fuse block which were all good.
Also, it appears there are no lights working in the gauge cluster, but the water temperature and oil pressure gauges work. The fuel and ampere gauges do not work.
So, could I have two door switches and a headlight switch all fail together? As I understand the dome light circuit, the switches are wired in parallel, so one bad switch would still allow the others to feed power to the bulb.
The headlights, turn signal lights, taillights all work when the light switch is set to the appropriate place. The hazard switch works correctly.
These are the possibilities as I see it; a broken wire somewhere in the dome light circuit downstream from the light switch, a bad light switch, a loose power feed to the light switch, a bad fuse or ……. some other gremlin.
Any thoughts would be welcome. Thanks.
