I assume you have taken all the "visible" bolts loose.. There is a catch on the bottom of the window you have to take off to allow you to get the window to come out the top. There may even be two,,, It's been a while. look along the bottom of the window frame.
There is also a stop on the back of the window. you will need to take the allen screw loose.
