1 - 2 of 2 Posts
Hi there, My question is if I take out the door handles do I have to take out the door panel with it to. The other thing is If I don't have to take out the door panels, when I take out the handles can I put the springs back in it with the door handles. I hope you understand what I'm talking about! Thanks!
Supporting Vendor
NO.The door handle springs should be behind the door panel. When you take
off the handles the door panel will poof out. To put the handles back on
just push the spring hook up the handle and your done. If you are thinking
of taking off the door panel, please ask how or you will ruin your door panel.
There should be a plastic gasket between the door panel and the handle to
keep the handle from scratching the panel.
1 - 2 of 2 Posts
