Okay, I have this HORRIBLE rattle in my driver door. I pulled it apart to find that i have a broken window "rail". It is easy enough to fix... a few tack welds and its as good as new.
Here is the question. The window still seems to be loose. How much movement should a window have on its rails? mine will move quite a bit. I havent compared it to the other door. I also cannot see where anything is worn. Are there bushings on the "sliders" that run along the rail that can be replaced? we are talking about a 1970 here.
