1 - 16 of 16 Posts
I pulled my factory original aluminum door scuff plates off and found some significant corrosion around each of the screw holes.
I find it interesting that Ford used stainless fasteners for an aluminum plate when stainless is known to corrode aluminum. Maybe that wasn't well known back then.
Has anyone else seen this? Do you guys use stainless fasteners or switch to zinc? I think I'm going to go pick up some zinc screws to use instead.
760361
I think you'll find that 55 years of use and damp carpets will have a greater effect on the bright dip aluminum than the stainless screws.
Zinc screws will look like crap in short order.
Yeah, maybe you're right. Maybe someone cleaned the carpet with some salts and that's why.
The last thing that I'd worry about is the Stanless Steel screws... They sure didn't cause that corrosion...
The cars were only designed to last 7 years. :eek:
Reactions: ginpunk
My 1967 has the original scuff plates and stainless screws and the plate is fine. CA car. Probably another reason for yours to end up this way.
Discussion Starter #9
Yeah you guys are probably right, it's most likely salts from the carpet somehow, rather than the stainless to aluminum galvanic corrosion. Otherwise I think I'd see more corrosion on the top of the plate than I do. I'll continue to use stainless screws.
I don't know what hardware you have, But I think Ford used chrome screws not stainless. I think it's more the age of the Aluminum. You can put a LITTLE light grease in the holes.
Use a magnet to determine if they are stainless.
Not even. The warranty was 12 months, 12,000 miles, whichever came first. Except K codes, their warranty was 3/3. o_O
Warranty vs. Life of car was two separate things - Ford wanted you back in about 5 years to buy another new car
1 - 16 of 16 Posts
