is there any way to open up the door and look inside it instead of looking in just those little holes where you have no room to move? i need to find out what is wrong with the window and i cant seem to get a good enough look inside of it!
Sorry guy you're pretty much stuck with the little holes unless you cut off the door skin and replace it.
Every day is a holiday if you love your job.
Current projects: 65 Fastback, 68 Coupe Oval Track Racer, 64 Galaxie 500 XL, 54 F-100 Pickup
The only access you have is the holes behind the door panel.
Adrien.
65 GT Coupe all dismantled waiting for resto.
67 Restomod Coupe all sheet metal done, next is assy.
69 Mach 1, SWMBO say don't you dare take it apart!
91 5.0 LX HB, daily driver.
Discussion Starter · #4 ·
This being St.Patricks day , there may be a very little (green) guy who could look in there for you.
Happy St. Pat's........ a bad day for snakes.
jimbo
M.C.A.# 50000
http://albums.photopoint.com/j/View?u=1575692&a=11979479&p=43517165.jpg
I take it you'd rather not remove the window if you can help it. I don't blame you, even on a '65, the simplist of the bunch, it's a PITA. I find a flash light or trouble light and a small mirror helps. I guess the Vintage Mustang door styling is the price to pay. I just yanked a window regulator out of a '65 Ford Galaxie today and because it had full door panels it was a lot easier to remove than the limited access of our 'Stangs.
Good luck!
Dean T
