1 - 20 of 23 Posts
· Registered
I wanted to add a modern HD radio with navigation to the 66 vert I am restoring. I did not want to cut up the dash in case I wanted to maybe use the original radio etc.
Pioneer and maybe some others, have bought out a radio which has the display separate from the body and linked with a cable. I measured the smaller Pioneer model and it fits. I made a thin bezel that attaches on the side to display that matches the shape of the dash, need to finish it a bit better and paint them maybe white which will be the color of the dash. I made some brackets with captive nuts so the display is held in place with 2 screws through the holes of dash where the volume and tuning knobs would be. The body I will fix in place behind the dash when I have worked out other "stuff" that might be in the way.
This is the radio I used.
I will most likely run the wires for the front and rear camera, could help to park the car safely in the garage.
No dash was harmed in the fitting of this radio and the ashtray and heater controls will function as normal.
· Just some guy
I do believe this to be the very best implementation of later style radio in an early car I've ever seen.
· Registered
Discussion Starter · #8 ·
I test fitted the cable to the display, it is not fully plugged in. The brain was sitting on the cowl / windshield flange through the speaker hole, it is a reasonable length. If you don't fit the windshield you could leave it up there. ?
The brain is not big, same width as display 7 x 5 1/4 x 2", maybe the same size as a regular radio. As it does not have a CD / DVD it does not matter on orientation, it has a small fan. I am hoping it will fit behind the display maybe mounted to the ashtray mount or from the dash above.
The other picture is the rear of the display with the test brackets.
· Registered
Good job putting 6 screw holes in the LCD chassis. I bet that wasn't covered in the installation instructions. There are extension cables available. But I'm sure the OP will build a nice little bracket for the black box.
· Registered
Why not 2 studs to mount to dash ? Looks good.
· Registered
Discussion Starter · #13 ·
The display fits quite tightly under the dash so I would not be able to fit the display then the dash pad afterwards. Using the old radio knob holes holds the display nicely in place against the dash.
I did put the link to the radio I used in the first post but seems to have gone.
Pioneer DMH-C2550NEX
· Registered
1965 Coupe C-Code
I was going to do it like this. I don’t like the idea of the screen visible when parked, especially in my case with a convertible.
· Registered
If you want more room you can go with the 65 dash pad.
· Registered
Discussion Starter · #16 ·
This is for a convertible. I installed a Pioneer double din years ago in my sons Saab convertible. I took a picture of the stock radio and mounted it on the trim of a double din radio. When he parked the car he would clip the trim around his Pioneer display. From outside the car it looked quite good and made the car look quite stock. I will most likely do the same thing.
If somebody wants to steal your stereo or your car, they will.You can make it awkward for them but if they really want it, they will take it. Enjoy your car while you have it.
The reason I wanted a display type of radio was for navigation, maybe for phone. So I wanted to see it and not have to glance down too far when driving. The other option would be a display that pops out of the center speaker grill but that would stick too far up if I kept the stock dash.
· Registered
Very clean!! Nice!!
· Registered
No ,I like that you used the factory radio holes but wondered why you did not use a stud which might make it easier to attach to dash as opposed to trying to reach back there and put in a screw.
1 - 20 of 23 Posts
