Does anyone know the drive shaft stripe colors and locations for an early 1964.5 F code Dearborn convertible, 260 V8 / C4 auto with factory air? VIN 5F08F151954
I actually dismantled and carefully cleaned the drive shaft today. I found evidence of three (3) ) stripes but, no colors were revealed. I was able to measure where the lines were and this is what I found, measuring from the rear of the shaft from centerline of the U joint:
  • 1st stripe; 14 3/8" to the center of a 3/4" wide stripe.
  • 2nd stripe; 30" to the center of a 1/2" wide stripe.
  • 3rd stripe; 33" to the center of a 5/8" wide stripe.
These are fairly accurate in distance from the U joint but, the width is approximate. The colors were non-existant. I am positive that drive shaft is original to the car and it is a numbers matching car.
I just wanted to post the findings in hopes that it may help someone else. I am still trying to figure out what colors the stripes were.
So here's the drive shaft now and you can see the original stripe locations. The front is on the right.
Someone said a build date might be helpful in finding someone with a Dearborn car built in the same month. The stripes should be the same. My build date was 29F (June 29).
