My driver's side taillight is dim and the turn signal on that side does not work. The passenger side works fine, so I do not suspect a bad blinker. I changed the bulb with no improvement. I cleaned the receptacle, no improvement. I can stick my tester probe in the housing and the backup light on that side will blink. What gives? I suspect a bad bulb receptacle, but am not sure. Any tips? It was working fine the other day, now it's on the fritz....
When I can't stand, I must lean...
When I can't see, I must believe....
