Hey guys!
So I have a 67 mustang and in it I have a 68 302, a c4, and an 8 inch rear end. I’ve tried to look for a driveshaft for a 68 302 and c4 but all I get are driveshafts first a T5 conversion. Does anyone know what length or better yet, what driveshaft I can through in the 67? Thanks!
My 67 C4 driveshaft is on the garage floor. Im going to say 50.75" from center to center of the u-joints.
Hey guys!
Here's a PDF document I've had that has all the driveshaft and yoke dimensions, as well as applications. It is best to verify the dimensions before trying to order one.
Hemi, thanks for the pdf.
My 67 is a late build 200/C4. It has a 3" diameter driveshaft that was standard in 68, not the 2.75" diameter driveshaft a 67 would have had. Of course who knows what was changed over the years.
The rear u-joint is to small for the 69 8" rear end that I put in it.
I'm using a Exploder 4 door 2WD aluminum driveshaft I paid $65 for. They're 50.5". Mine was from a 94 V6, it uses the same 1310 U joint as Mustang. You want 94-01. Most seem to use the 1330. You can get a 1310/1330 combination, they're fairly common.
