I was wondering how much of the slip yoke should be sticking out of the tailshaft of a C4 when the car is sitting level and not moving? I'm starting to think my driveshaft might be too short.
About 2.5 to 2.75" from the back of the trans case to the CL of the u-joint bore....
Also, check your dimetral yoke clearance by attempting to wiggle the yoke up or down .....you should not be able to see any movement but might feel a little bit...
What symptoms do you have to lead you to suspect the driveline being too short?
Pat
Thanks for the info! I'll check the dimensions tonite.
I recently replaced my worn factory trans mount with a polyurethane mount. After doing so, I started getting very intense vibrations that started at about 60 mph. Before I could take it up to 75-80 no problem.
My guess is some kind of driveline problem, which the old, worn mount was masking. Possibly out of balance driveshaft, bad U-joint, something like that.
Working under the car, I did notice that about an inch and a half of the exposed, machined portion of the slip yoke was sticking out of the tailshaft, which seemed like a lot to me. Just wanted to check and cover all bases.
I once asked a drive shaft place this same question; they said only about an inch or so. I was curious, because I suspected inadequate penetration of a driveshaft, causing my rear bushing to fail, causing my driveshaft to flail, causing my tail housing to shell (into two autonomous pieces). Now I just tell the guys it's x inches from the tail housing to rear u-joint centerline... PLEAASEeee make me one... by Saturday night's drags??????!!!!!
Tom Kubler, Long-time Mustang Enthusiast & San Antonio Mustang Club Founder
