I guess I'm good to go on this setup?
If going the Ford route.Ok everyone so after going back and forth on whether to buy the pertronix 3 module and deal with that again or doing the Duraspark 2 conversion I have decided to covert to Duraspark 2. I just have a few questions to ask.
1. Can I still use my coil? Pertronix 40,000 Volt 1.5 OHM with the Duraspark 2 setup?
Yes.
2. Do I need to disconnect the Pink Resistor from the ignition switch No, Leave all that stuff alone. ...and run a new 12 volt line? Yes, but just to your ECU, whether it be a DurasparkII, GM or Mopar. Bring a new wire from the Ignition switch "C" terminal through the firewall or use a relay triggered by a "switched ignition" source, such as the back-feed to the solenoid "I" terminal.
3. Can I use the (Distributor Part # 12127) that my brother gave me on a 1987 5.0 roller converted to carburetor? I think the gear " Steel" is compatible. Correct me if I'm wrong?
As long as it's a DurasparkII, with a vacuum advance unit.
4. Is it worth buying the Painless Harness? https://www.summitracing.com/parts/prf-30812
Not in my opinion, plus you can't use the coil connector with your Pertronix Coil.
5. Is there a difference between these two modules besides price?
https://www.summitracing.com/parts/smp-lx203t
https://www.summitracing.com/search...eywordMatch&SortOrder=Ascending&keyword=dy893
Yes. One is a "DIY-er Grade" and the other is a genuine Ford product. Be sure you get the right ECU for the distributor being used. There are 5-pin modules for distributors with a 3-pin plug and 8-pin modules for distributors with a 4-pin plug.
6. These are the specs of the motor that it will be feeding. Any benefits to getting the distributor recurved or should i just leave it alone and see how it runs?
There are ALWAYS benefits to having the advance curves tailored to the specific build.
Stock bottom end
Ford Motorsport E-303 cam
Ford Motorsport 1.72 roller Rockers
Heads are World products Windsor Jr. Heads – 1.94/1.60, 58cc chamber
I'm I missing anything else?
Thanks in advance![]()
IIMO, this is poor advice. There are 2 ignition circuits - one for starting/cranking, one for running. The starting circuit powers the coil from the brown wire that comes from the solenoid. This provides a full 12V while cranking. The white wire to the module should be connected to this circuit. The red wire should go to a 12V "accessory" power source that is active when the key is in "on" or "acc". This is the power source that will be active for the engine to run. If you only have the module white wire connected to the brown wire circuit, the engine will crank and fire, but will shut off when you release the key to the "on" position.There’s a white wire on the Duraspark plug. It’s to retard the timing while cranking. Don’t connect it. When I did it would only fire the coil while cranking and of course the engine ran. As soon as I released the key to run, it died. It starts fine.
It's probably easier (and cheaper) on a "conversion" to buy the individual plugs ("repair connectors") and make up your own harness. You'll need the 4-pin and 2-pin female module connectors and the 3-pin female distributor connector, a ring terminal or 90* push-on for the ignition coil and, if I were doing it, male and female bullet connectors for the connection to the existing under-hood wiring.So does it look like I could possibly find new connectors for this setup? And is it worth using the distributor in the video?
I have pulled the vacuum advance unit to clean it up. I will be pulling the breaker plate to see what's going on.It's probably easier (and cheaper) on a "conversion" to buy the individual plugs ("repair connectors") and make up your own harness. You'll need the 4-pin and 2-pin female module connectors and the 3-pin female distributor connector, a ring terminal or 90* push-on for the ignition coil and, if I were doing it, male and female bullet connectors for the connection to the existing under-hood wiring.
Would you happen to have some part numbers I could use to order those module connectors?
As for the distributor in the video, it's lacking the vacuum advance unit and I'd pull the breaker plate to see what's flopping around below that seems to be catching something.
The S terminal on the solenoid only has 12 volt when the key is in “start”. When key is is in “run” no power to it. 12 volt to the coil when starting is a function of the ignition switch. So when the key is in start, 12 volt is supplied to the S terminal to engage the solenoid and feed the coil. No I did not have the white wire connected to brown. Wired like it’s shown to the S terminal.IIMO, this is poor advice. There are 2 ignition circuits - one for starting/cranking, one for running. The starting circuit powers the coil from the brown wire that comes from the solenoid. This provides a full 12V while cranking. The white wire to the module should be connected to this circuit. The red wire should go to a 12V "accessory" power source that is active when the key is in "on" or "acc". This is the power source that will be active for the engine to run. If you only have the module white wire connected to the brown wire circuit, the engine will crank and fire, but will shut off when you release the key to the "on" position.
+1 on all of Woodchuck's input.
After my third MSD failure in 15 years I switched over to a Duraspark system. I love it, especially the white 'retard' wire.
I have to ask - why the Summit boxes? I used Ford blue grommet boxes and repair connectors from RockAuto.com. I haven't compared, but I bet they are cheaper. After all of the MSD issues I went off the shelf so I can get parts anywhere - even a junkyard if need be.
Is there any other connectors I need to order?I looked up my Rockauto order for the Duraspark conversion; here's what I used:
Module: More Information for MOTORCRAFT DY893
4 pin connectors: More Information for STANDARD MOTOR PRODUCTS HP4735
3 pin connector: More Information for STANDARD MOTOR PRODUCTS HP3935
Do you have any pictures of your setup/ wiring?I'm running duraspark off the pink wire...no issues. I use the white wire for cranking retard. I made my own connectors using advice from woodchuck...or someone on using a 4 flat trailer plug to make conections. I put a 4 flat on box and on dizzy, then use a 4 flat extension harness to connect the two harnesses together. It makes it easy to switch out boxes if one goes bad.
Bob, you should know better!! We now have to say "spark advance challenged".I love it, especially the white 'retard' wire.
