Well if anyone has pictures of their setup and wiring harness feel free to display your work so I could get some ideas!!
Thanks in advance guys..I will keep everyone updated once I open up the distributor and see what is causing the fiction. I might need to end up buying a distributor as well... Aww money pit!! But I sure love my toy!!
youtube.com
It's pretty simple, really. First, find a location to mount your DurasparkII ECU ("box"). They do NOT like heat, so my suggestion would be, if I was putting in a '65-66, in the void between the right rear apron and the right front fender, behind the splash shield, with the wires going through a grommet below the hood hinge.
You'll want the Standard Motor Products HP4735 4-pin plug, HP3935 3-pin plug, a 2-pin waterproof connector kit (male and female plugs), 5-foot or more rolls of 100% copper stranded primary wire in 16AWG in, preferably, red, white, black, green, purple and orange, two 16 gauge 3/16" ring terminals, a dozen shink/solder butt connectors, a "solid" grommet for a 1" hole and one for a 3/8" hole.
1. Cut the 2-pin plug from the Duraspark ECU and attach the MALE plug of the 2-pin waterproof connector, red to red and black to white. On the FEMALE plug, connect the spool of red wire to the red and the spool of white wire to the black.
2. Between the HP4735 and the HP3935 plugs, connect the black, orange and purple spools between them according to the diagram below. On the HP4735 plug, connect the green spool according to the diagram below. This wire doesn't go to the other plug.
3. Unroll the spools estimating how much wire you'll need to go from the ECU to the ignition switch with the red spool, to the starter solenoid with the white spool, to the ignition coil with the green spool and to the distributor with the remaining 3 spools.
4. Cut the wires with enough extra in case you make a mistake!
5. I'd run the wires through woven loom but that's just me. Run the 6 wires from the ECU out through the grommet and hole you drilled in the apron.
6. Put a ring terminal on the end of the white wire and attach it at the solenoid "S" post.
7. Put a ring terminal on the end of the green wire and attach it to the ignition coil "-" or "dist" post.
8. Run the red wire though the 3/8 grommet and the hole you drilled in the firewall to the "C" terminal of the ignition switch plug. Probably the EASIEST way to connect is to buy 2 male and 2 female .180 "bullet" connectors. Take 2 short (3") pieces of your left-over red wire and place them parallel to each other. On one end, twist the conductors of the two wires together and place the MALE bullet on that end, and each of the FEMALE bullets on the other ends. At the ignition switch, disconnect the bullet connector between the RED/GRN and the PINK wire and insert your new "adapter" between the RED/GRN and the PINK wire. Place your remaining male bullet on the end of your red wire from the ECU and plug it into your adapter.
