1 - 20 of 23 Posts
Hey guys/gals,
Going to get the car tuned up and dyno tested this Thursday and Friday! I have a 347 stroker and a .520 -.523 lift cam (hydraulic). Alum. Edlebrock intake- Holley 600 cfm. Alum. heads- CNC intake and exhaust runners. Bigger valves 1.60-2.02. Long tube headers. Only running an alt belt-electric h20 pump. Guess on the RWHP and lets see who gets the closest!!!!
shootin' from the hip... 310rwhp?
Which type of dyno - ex. Dynojet, Mustang Dynometer?
They'll give different readings. About 13% higher on the Dynojet,
Discussion Starter · #5 ·
1. The heads are Victor Jr. knock offs :/
2. Edelbrock Performer RPM 289-gasket matched and ported.
3. Cam specs- Duration at .05 is 230-236
Lobe sep-110
4. Its a Mustang Dyno.
310-290 are the only 2 guesses?
Discussion Starter · #7 ·
Wow thats pretty good and whats it for a C4 a normal 20% loss?
Id figured It would be around 350ish at the crank.
Your figures seem about right. The PC dyno usually is high. Good luck at the dyno, and let us know!
I'm going to guess 345rwhp on a dynojet as bob's untuned 331 made 323hp and this sounds fairly similar, with a little more heads and intake and a little less cam, along with 16ci more. Not enough carb though, I bet a 750cfm would give you 700rpm and more horsepower.
Discussion Starter · #10 ·
I used a formaula I found online for that and the equation said something like 615 cfm-or am i still high from exhaust?
Discussion Starter · #11 ·
No other guesses for rwhp numbers? Well times getting close- will post them and probably some tears with the low numbers!
i'll go w/ 250...just because :p
I, also, think you are going to be leaving a little horsepower on the table with that 600 cfm Edelbrock. Ask the dyno tuner what carb he suggests you run.
Tim
Discussion Starter · #15 ·
Yeah-let me look at the carb equation again to see what it suggests I use. Have you guys seen the formula before? Ill see if I can get it on here!
Marcs66and06 said:
http://www.classictruckshop.com/garage/shopmathcfm1.php
Okay heres the formula- it still only calls for a 650 @ 100% VE
I had a 650 in mind for the biggest carb I would try on a 347. Anything more will net higher peak horsepower, but will cost bottom and mid range in my opinion.
What's the compression ratio of your engine?
1 - 20 of 23 Posts
