Do they come with outlets? What I mean is... if you noticed on this picture there is no shafts coming out of the outlets. How do you connect the hoses? Do you have to buy them separate or are they just not in the picture?
http://store.summitracing.com/global/images/prod/large/EDL-8845.jpg
They come with two brass screw in outlets. I wonder whether AN fittings would screw in? Would be a classy look with braided stainless steel heater hoses. Have to find out whether the threads are different. Oh well, just a little musing. The brass outlet/inlet pipes are graduated (or stepped) in diameter for a snug fit on the heater hoses (which should be 5/8ths inch hoses). good luck. Just make sure you have the correct year water pump because the main outlet changed sides in 1970, as did the inlet to reflec the fact that Ford changed the upper radiator inlet in 1970 to the other side of the radiator. The lower hose is on the driver's side and upper hose on the passenger side 1970 and later. Reverse for 65-69.
