ok, what order do these washers go on the 67 strut rod bushings? i figure that the fat end of the bushings go towards the frame, the dome washers go outside of that, and the funky washer goes between the bushing and the frame, now is it front side or control-arm side?
like this?
front ----- ( O frame { O ) ----------- arm
or
front ----- ( O } frame O ) ----------- arm
for my '68 (should be like yours) my Can Mustang parts went from LCA like this - back nut, dome washer, rubber, cup (your funky) washer thru frame then rubber, dome washer, front nut and finally safety nut. my Shop Manual shows a spacer between adj nut and safety nut but none was on my original. Questioned Can Mustang on this and was told that spacer not needed and funky washer could be put on either side but it looked like it belonged on LCA side. PM me if questions.
aha! thanks! I couldnt find any diagrams or anything showing the order, nor anything in the search archives.
