I have a chance to pick up a complete EFI set up from a F1SE-BB-9 1994 Mustang 5.0/302.....My question is will this work on my 68 J code 302 ?
Complete engine and efi, or just the efi?
I'm using the complete engine and efi in my 65. Mainly for the ability to control the 4 speed auto.
The T-Bird intake that was used on the 94-95 is down on power from the Fox body cars, but it can fit under an export brace ... just.
The firing order is different between the 94 5.0 and 68 302, You will need to change the injector wiring.
It's just the EFI.....It's in a running Mustang....He wants to go to a carburator ! Don't know why !!!!
Consider fuel tank, pump and return. Efi requires pressurized, sealed, fuel delivery. Everyone always overlooks the cost of a tank, pump, and return.
Wiring on the 94-95 is more complex than Fox stuff. The resistor trick for EGR sensors doesn't work on them. Need some way to tune them out of the ECU. Changing the cam to a flat tappet version of the roller cam would be more successful than trying to get it to work by changing injector wiring.
By the time you finish, you'll have a lot more in it than you think ... even if it was free.
